Memory for the displayed object could not be allocated. The system is not functioning as expected. MACsec cannot be enabled on this port. Possible object types: pib_macsec_data_s.
Check the scalability limit and compare this with the current configurations. Reducing the system configuration may help reclaim memory.
Critical
Memory allocation failed when trying to allocate a %obj% structure for port %slotPort%.
| Name | Type |
| obj | String |
| slotPort | SlotPort |
